enable cli prompting
Description
Enables CLI prompting for the session.
Syntax Description
Default
Enabled.
Usage Guidelines
Use this command to enable CLI prompting from a disabled state.
To view the status of CLI prompting on the switch, use the show management command.
The following command enables prompting:
This command was first available in ExtremeXOS 12.5.
Platform Availability
